H starting tank stuff
sgtbull
03-09-2006 07:09:20
Anyone know where I can find a cap and the valve assembly for an "H" starting tank? Found a tank, its rough, but it'll just be for looks anyway...gotta fill that hole in the hood.
Fancy Farm
03-09-2006 20:38:37
 Re: H starting tank stuff in reply to sgtbull, 03-09-2006 07:09:20
Just got through with a H got the tank cap from OEM it works well but the trick to the starter tank was getting a fuel boll with 2 inlets in it so I could put the fuel line on the small tank. You can't buy the right fuel tank straner to hook up the small tank because I didn't want the small tank to have fuel anyway I bought a new strainer and cut the fuel line fitting off an old strainer body I had and used poxyputty to mount it on the new strainer and hooked the gas line to it works and looks fine. You can get a 3 foot section of 5/16 copper and 2 fittings from IH and make a gas line for it fo $5.00 or buy one for $26.00
NDS
03-09-2006 15:25:27
OEM tractor parts has the caps. The valve they show looks like dual outlet type but they do say so in catalog.
Yugrotcart
03-09-2006 12:47:41
I have seen new caps on Ebay and valves as well. I bet the dealer can get them also.I have an extra tank, with cap and valve. Only thing is, it comes with a '44 M..... ..... ..lol
