bent 1086 hyd couplers
Turk
03-09-2006 08:00:26
While making a tight right turn with the V-plow lifted up my hitch broke and put a lot of stress on the hydraulic lines all of a sudden, and leaned the hydraulic couplers to the outside. I have seen a few tractors like this and now I understand what happened. Question is, has anyone tried to bend the whole assembly back 'cold' or do you have to remove the lines and straighten or replace them? They still work fine but look bad, they now come out at about a 45 degree angle instead of straight back, took a pretty good bend. Thanks Bill
Janicholson
03-09-2006 12:01:21
 Re: bent 1086 hyd couplers in reply to Turk, 03-09-2006 08:00:26
If you can't stand them bent, use a tubing bender, and bend them back. Crack check them to be sure they are sound. Hot oil under tremendous pressure is very harmful to living things. The pressure can drive petroleum oil through your skin and cause drastic health problems.
JimN
