Swapping Trannys!..........Ya I know!!!!! Farmall
Scott Swanson f
03-09-2006 10:02:52
I have three Farmall H's with good engines and bad transmissions. I have three Farmall H's with good Transmissions and bad engines. Most of my tranny and engine problems are significant.
Question:
It there something wrong with swapping trannys?
Can a 1942 tranny be used on a 1946? Are there alignment problems?
Any concerns or thoughts on this?
Thanks,
Scott
Nat 2
03-09-2006 10:32:35
 Re: Swapping Trannys!..........Ya I know!!!!! Farm in reply to Scott Swanson from Hubbar, 03-09-2006 10:02:52
So long as you don't care about being 100% original, numbers "matching" (i.e. engine and tractor serial numbers close) then split them behind the engine and swap them as you deem appropriate.
