300 Utility hydraulics
biggerred
03-09-2006 13:09:11
Just ahead of the single valve for the quick hitch, is a blank space(on the side of the res). It has some pipe plugs in it, and looks like there was something there at one time. Got any ideas? I want to put a loader on it(another story), but it has no remotes. Any suggestions?
Jimer
03-09-2006 17:58:26
 Re: 300 Utility hydraulics in reply to biggerred, 03-09-2006 13:09:11
You are correct according to my 300u. I have two remotes in front, the inside is the up and down on the bucket and the outside is the tilt of the bucked. I also have two in back, the inside is the power steering and the outside is the 2pt hitch.
biggerred
03-10-2006 08:13:16
 Re: 300 Utility hydraulics in reply to Jimer, 03-09-2006 17:58:26
Got any pics of the set up? That might explain why my PS dosen't work.
Gene Brooks
03-09-2006 13:32:49
My 350 utility has the same thing it's for another add on ;you can use it ,but be sure to buy the same valve that you use for your quickhitch plus the [regulator,regulates to 1200 lbs psi] should be enough for loader and quick hitch,[providing pump is good !! ] Gene
