H rocker arms... please explain 2 different styles
arod
03-10-2006 10:19:45
straight, versus slanted in my parts pile and both are interchangable. Is one a super h?
thanks
aaron
Dave Slater
03-10-2006 12:26:51
 Re: H rocker arms... please explain 2 different st in reply to arod, 03-10-2006 10:19:45
Need to correct last post,looked at set to see if I remembered correct. On steel set I looked at only 2 different numbers all offset with offsets
toward each other when mounted.Each set off arms agian mounting post the offset went toward each other. Hope I made this understandable.
Dave Slater
03-10-2006 11:51:51
They made forged or cast arms on H and then went to what they called welded type made out of steel and was used on H, SH through 350 also. If you have arms removed from shaft theres 4 different 2 each.
You would need to put them on shaft so they line up with valve and push rod when installed on head.
Janicholson
03-10-2006 10:47:50
Aaron, There may be the need for part numbers or photos. Lack of response might indicate the need for more info. I know of no "slanted" type for an H. Many engines are in this same family, so if we had #s maybe someone could help.
JimN
kfox
03-10-2006 13:57:08
 Re: H rocker arms... please explain 2 different st in reply to Janicholson, 03-10-2006 10:47:50
My shop book says that the intake valves don't get oiled. Maybe that would help identify. ken
