Diesel Question
Reddog
03-10-2006 15:47:48
This question is OT for this forum but you guys have never let me down. I have a 1998 Cub Cadet compact tractor with a 20hp. three cylinder diesel engine (I think it is a Mitsubushi) I hadn"t started the tractor in about 6 weeks and when I went to start it last week the battery had given up. I just put a new battery in it tonight, and now it won"t start. It is cranking over really good, the glow plugs check out and I can hear the electric fuel pump working. It really never got that cold here this winter and I put anti-gel stuff in the fuel last fall before I parked it in the workshop. The tractor only has 62 hours on it, so I hope nothing major is wore out. This is the first diesel I have ever owned, I am more acustomed to working on my 49 Super A. I don"t want to just start tearing into it, so any ideas what is wrong or what I should be looking for would be much appreciated.
As always thanks,
Mike (Reddog)
El Toro
03-11-2006 14:01:10
 Re: Diesel Question in reply to Reddog, 03-10-2006 15:47:48
Not sure about your engine, but the Detroit diesel
has an emergency shutdown. If someone accidently
pulls this the engine will smoke, but won't start.
When this is activated it shuts off the intake air to the engine. The Cummins uses a lot of overspeed shutdown. This is usually connected to the tach drive driven by the cam. If this engine happens to go above the set speed on the overspeed it won't start until the overspeed is reset. I would give that engine a little whiff of ether to see if it fires without the glowplugs.
Hal
banjo
03-10-2006 16:47:59
fuel, air , compression ,should start with those. it's not getting one of those three. if you have air in the fuel line that would cause it not to start also.
My a/c 170 is tempermental if it is cool outside. but it doesn't have a glowplug or intake heater.
the tractor vet
03-10-2006 16:19:52
Is the magnetic shut down working ??? sometimes they stick a buddy of mine has one of them super tractors and it did this once and that was the problem.
Reddog
03-11-2006 04:50:12
 Re: Diesel Question in reply to the tractor vet, 03-10-2006 16:19:52
Thanks for the suggestions guys. Tractor Vet what is the magnetic shutdown ?? I forgot to mention when I am cranking it the motor is putting out a nice blue exhaust smoke just like it normally would when it first starts. Thanks for the help.
Mike
the tractor vet
03-11-2006 06:37:35
 Re: Diesel Question in reply to Reddog, 03-11-2006 04:50:12
Well if it is smoking then it is getting fuel so then the glow plugs are not working so i would be checking the glow plug relay and maybe the glow plugs .The shut down seleniod is a round metal deal with and arm -rod comming out of it going to the lever on the injection pump and there are some wires going to the back of it , when you turn the key on this opens the furl valve in the pump when the key is turned off a spring pushes it foward to shut off the fuel . when this does not work then there is no smoke . If the glowplugs don't work there is smoke but no fire it could be just a stuck relay.
Reddog
03-11-2006 17:12:51
 Re: Diesel Question in reply to the tractor vet, 03-11-2006 06:37:35
Thanks Tractor Vet, rechecked everything including pulling all the glow plugs out and testing them on the bench. Two out of three glow plugs are bad, I assume once I get these replaced my problems will be over. Thanks for the advice.
Mike (Reddog)
