Piston Kit Super C
Joe Melwiki
03-10-2006 18:14:31
Just got done installing a piston and sleeve kit in my Super C, my first rebuild. Everything went smooth, installed the rings in the order they were supposed to go, as well as how they were laid out on the instructions. Put everything back together but have not fired it up yet, but it turns over real nice with hand crank. My concern is this, I did not realize I should have checked the ring gap before proceeding to install the rings. Is this O.K. or should I tear it all apart and start over again?
trickster
03-11-2006 03:11:09
 Re: Piston Kit Super C in reply to Joe Melwiki, 03-10-2006 18:14:31
I just did a super C sleeve kit and I checked all the ring gaps, and they were all good. so if it was me I think I would assume it's good if it came in a kit
kfox
03-10-2006 20:36:40
If the rings came with the kit, you should be OK.
MagMan
03-10-2006 18:20:44
Your fine, Unless you had undersize rings or something stupid like that. I would not tear it down. JON
Farmall Magneto site
