MD Carburetor Part #
Farmall Frank
03-11-2006 18:14:43
Could someone post the part # for an MD carb? Wanted to know if it is the same as the 400D, which is 67860DCM.
Is it actually marked on the carb, and if so, where?
Dave Slater
03-11-2006 18:43:22
 Re: MD Carburetor Part # in reply to Farmall Frank, 03-11-2006 18:14:43
The # is on a little round brass tag. The choke shaft is different on 400&450 compared to MD and SMD. They will bolt on and work if you fix choke linkage to hook up with whichever linkage, rod or cable.
Dave Slater
03-11-2006 19:05:34
 Re: MD Carburetor Part # in reply to Dave Slater, 03-11-2006 18:43:22
Forgot to post # for MD carb, 53873 D? and the tag should be on top edge of carb.Where I put question mark after D in part # several letters were used the latest I have seen is DH.
