Does a IHC -140 HC Do The 2-Step?
Ida Red
03-12-2006 07:10:45
Does a 140 HC have a two step transmission and how many of these tractors were built? March13,2006 Red
Haas
03-13-2006 09:48:15
 Re: Does a IHC -140 HC Do The 2-Step? in reply to Ida Red, 03-12-2006 07:10:45
AS to numbers of high clear tractors produced. Don't know how many, but maybe if you post again, someone that has done research in the IH archives will answer with the number. A total of 50,000 plus of the 140s were produced from 1958 through 1979. However, the high clear versions did not have separate serial numbers, but rather were just serial numbered in the overall 140 sequence.
Haas
03-12-2006 14:39:47
Are you talking about a Farmall 140 high clear?? If so, they have the same transmission as the standard 140 which is 4 speeds and no range selection. Most have a PTO, but it is not live or continous running.
