Correct way to hold down suitcase weights?
jd jim a
03-12-2006 14:05:44
What's supposed to hold the early style of IH suitcase weights tight to the bracket? These are the ones that have about a 1/2" hole in the bottom, looks like to run a bolt through up towards the bracket? These aren't the ones that you run a piece of angle iron through.
Jim1206
03-13-2006 05:45:56
 Re: Correct way to hold down suitcase weights? in reply to jd jim a, 03-12-2006 14:05:44
What size bolt was used to secure the older style without the L shaped cutout? I had the same question as I have been trying to figure out how to tighten mine as well.
Levi K
03-12-2006 16:47:59
Wish I had a picture of 'em but tractor vet's right that's how they stay on.
the tractor vet
03-13-2006 08:48:11
 Re: Correct way to hold down suitcase weights? in reply to Levi K, 03-12-2006 16:47:59
!/2 inch-5/8 ?? don't remember and they also used a square nut been to long since i use them now we just cheet when we put the weights on for plowen we just use some tarp straps and try and not drop the ft end to much. and bounce them off.
the tractor vet
03-12-2006 14:12:17
each had a hole thru the bottom on and angel that you would tighten up aganist the bottom of the weight bracket , then on the later ones the had a l shaped slot thru the weight that a pice of angel iron went thru and it bolted to the weight bracket .
