As Max would say
VAJerry
03-12-2006 14:06:29
third party image
I was this close. Decided today was the day to rebuild the touch-control for my Super A. The one on the left is the one that was on the tractor when I bought it. You can see its been busted and welded. The one on the right came with the tractor and I was told it just needed to be put on. Well it worked fine so I thought no hurry, so fast forward to today. I was just going to rebuild the unwelded one. Right. Everything was seized up tighter than a certain tailer's wallet. So started with taking the old one apart to see how it cane apart and then got aggressive with the seized one and used the parts from the old one to replace the parts I damaged. There was so much crud in the new one I bet the pump was trashed when they took it apart. Cleaned every thing up with mineral spirits and WD40, flushed with hytran and reassembled. As I said I was this close 30 mins more and I would have been done but then it started to rain.
mark in WA
03-13-2006 06:23:01
 Re: As Max would say in reply to VAJerry, 03-12-2006 14:06:29
It is a strainer that goes inder the valve head. I just rebuilt one and I believe it goes in the lower right corner. The I&T manual shows where it goes, sorry I am not near my book.
CNKS
03-12-2006 14:51:07
Looks like the screen (filter) that goes in the big hole with the 4 bolts -- but I don't know how it got stretched, or where the rest of it is. How on earth did someone break a touch control unit??
VAJerry
03-12-2006 15:04:24
 Re: As Max would say in reply to CNKS, 03-12-2006 14:51:07
No idea but it is broken on both sides and has enough weld to hold 5.
VAJerry
03-12-2006 14:27:33
 One problem in reply to VAJerry, 03-12-2006 14:06:29
third party image
When I was tearing apart the intact touch control this metal piece fell out of one of the holes. The other one did not have it. Any ideas what it is, where it goes or if I even need it. This is about actual size.
El Toro
03-12-2006 15:02:34
 Re: One problem in reply to VAJerry, 03-12-2006 14:27:33
It's hard to tell, but it looks like a strainer
from the picture. Hal
