Where to get sector gear Farmall H
farmallwayne
03-13-2006 17:31:26
I need a new sector gear for my farmall h's. Where is a good place to get a new one from. I don't want to put a used one back on that is in the same shape.
Thaks
Randy S.E.-MN
03-14-2006 13:13:09
 Re: Where to get sector gear Farmall H in reply to farmallwayne, 03-13-2006 17:31:26
New ones are available through A&I products believe it or not...70-80 bucks...not bad for tight steering in my book...Randy
Buzzman72
03-14-2006 05:31:59
Have you tried just turning yours over?
randy hall
03-14-2006 14:36:54
 Re: Where to get sector gear Farmall H in reply to Buzzman72, 03-14-2006 05:31:59
how do you turn over a tapered spline gear?
PeteNY
03-13-2006 20:45:13
I just got one from a guy here in Upstate, NY that deals in IH salvage...it was for my Super H and not the full round but in great shape...works great. He does have the full rounds too...way cheaper than new. Email me if you want to contact him...he is a great guy...very trustworthy and a friend also.
Dave Slater
03-13-2006 18:46:10
Find a full circle gear that has never been turned on splines.You can inspect and tell by looking if teeth on one side were ever used or not.Put it on your tractor splines so center of unused part is as close to center of worm gear as you can get with wheels straigh ahead.After change you will only be on worn teeth when wheels are cut sharp and it wont be noticed then.
Andy Martin
03-13-2006 17:34:32
Why would you assume that all salvage parts are worn out?
I would never consider buying a new one.
Slappy
03-14-2006 01:49:18
 Re: Where to get sector gear Farmall H in reply to Andy Martin, 03-13-2006 17:34:32
Can you even buy new sector gears?
