Farmall A Filter/Oil
plh_in
03-14-2006 04:02:58
I just got a Farmall A. Where can I get the oil filter for this & what is the part no. when ordering it?? Also, should I use straight 30wt oil? &... how much (capacity) does this hold when refilling?
Is there a service manual that would be useful that I can still get?
Thanks alot!!
El Toro
03-14-2006 04:32:20
 Re: Farmall A Filter/Oil in reply to plh_in, 03-14-2006 04:02:58
Napa sells Wix oil filters and the filter number is 51172 cartridge and 51051 spin on. Any auto parts store can cross-reference these numbers too.
I would use #30 wt oil. It should hold 5 quarts. You should have petcocks on the oil pan for checking the oil level. It needs to be between these two petcocks. I would keep it at the top petcock for heavy usage. Check with Binderbooks for a manual or I&T manuals. Hal
Don L C
03-14-2006 05:20:01
 Re: Farmall A Filter/Oil in reply to El Toro, 03-14-2006 04:32:20
Binder BOOKS 503 684-0269
