power steering farmall 350
dspangle
03-14-2006 17:13:23
Trying to install power steering on a farmall 350
Iam not sure of the lift circuit block plug seal ring and lift circuit block plug where do they install at. Is it in the control valve that Iam replacing or is the block in the control that Iam taking off other tractor have this plug all ready installed in it?I just want to make sure I have all the parts before I leave the tractor Iam taking the parts from Thanks Dan
Dave Slater
03-14-2006 18:48:53
 Re: power steering farmall 350 in reply to dspangle, 03-14-2006 17:13:23
3 ports between inside control valve and reservior top post,its in lowest port could stick in valve or stay in reservior when you take apart.
the tractor vet
03-14-2006 17:20:28
Words to the wise TAKE IT ALL THE WHOLE SHOOTEN MATCH and use all from the donor tractor less headachs.
dspangle
03-14-2006 17:29:10
 Re: power steering farmall 350 in reply to the tractor vet, 03-14-2006 17:20:28
I guess that what Iam asking some has to know where the circuit block plug is? I hope is in the contol valve that goes with regulator flow valve ?
the tractor vet
03-14-2006 17:45:26
 Re: power steering farmall 350 in reply to dspangle , 03-14-2006 17:29:10
Been a long time since i have been into one and with out holdingit in my hand and looken i would be lien to ya .
