240U Rims
fredmich
03-14-2006 21:32:52
Are the rr rims for a Super A the same as what a 240 Utility would take? Also whats the biggest rr tires that would fit the rims. Thanks....Fred
gene bender
03-15-2006 02:40:54
 Re: 240U Rims in reply to fredmich, 03-14-2006 21:32:52
measure the width of the rim outside. If it measures 10in then its a 9in rim and then you can get a tire that will fit that rim. Example a 9.5 will fit a 8in rim just fine. 11.5 on a 10in 8.3 on a 7. Some tires will even say on the sidewall what size rim they will fit. Some people just ignore the rim size and go with whatever they want then end up with a bad looking deal. Bottom line its your tractor do as you like.
