Re: Super C oil check
scotty
03-15-2006 09:46:34
Look on the side of your oilpan. There are two petcocks, crack open the lower petcock and see if you have a drip on a level surface. If so you should be OK. If you have oil coming from the upper petcock, let it drain down before using the tractor.
scotty
