engine timing gears for 300 International
biggerred
03-15-2006 11:09:11
I have had an ad posted in the classifieds but have had no luck. I need the gear that goes on the pump (hydraulic) for a C169 engine (300, 300U, SH). Anyone have one "laying around"?
El Toro
03-15-2006 15:46:00
 Re: engine timing gears for 300 International in reply to biggerred, 03-15-2006 11:09:11
Send an email to bhershey@hoober.com or call them at 1-800-732-0017 and ask for farm tractor parts, they have garden tractors too. If there's a number on that gear it would help them. Hal
PS: They have 4 dealerships.
Dellbertt
03-15-2006 14:53:06
are you talking about the two pumping gears inside the pump. Is your pump cast or aluminum.
biggerred
03-16-2006 06:39:55
 Re: engine timing gears for 300 International in reply to Dellbertt, 03-15-2006 14:53:06
The drive gear(ON it, not in it)The Dealer calls it the distributer gear.
El Toro
03-15-2006 13:37:53
Have you tried your local Case/IH dealer? They may have that gear. You can try Carter & Gruenewald at 608-934-5201 or email them at juda@
cngco.com. Hal
biggerred
03-15-2006 14:55:30
 Re: engine timing gears for 300 International in reply to El Toro, 03-15-2006 13:37:53
My Case/IH Dealer couldn't find his butt with both hands. Anything older than the 90's and he's lost.
