715 combine engines
Mcred
03-15-2006 15:21:18
I bought a late modle 715 gas and it had a 301 gas, have a friend with a late modle 715 gas and looking at a early modle 715 gas and neither one of them two have the cid stamped on the block, anyone know why? would these also be a 301? the stamping on my block is plain as day and the other two engines I cleaned up real good and there is no stamping at all. Justin
El Toro
03-15-2006 15:40:09
 Re: 715 combine engines in reply to Mcred, 03-15-2006 15:21:18
My book only has the 301 engine listed for the 715, it has the 263 for the 615. Hal
Mcred
03-15-2006 17:25:59
 Re: 715 combine engines in reply to El Toro, 03-15-2006 15:40:09
Thanks, Justin
Mcred
03-15-2006 15:39:26
Thanks alot ejr-IA I was looking under the distributer theres a flat spot there to mine has 301 there and Grandpas 560 has 263 there also Ill look up there to next to see, thanks again. Justin
ejr-IA.
03-15-2006 15:29:32
You are looking on the wrong side for the 301 numbers.Look on the right side up by the water pump on the block theirs a flat spot with the stampings.
