Tractor wheel spacings
Allan in Nebras
03-15-2006 15:56:40
What should the front and rear tractor wheel spacings be to pull a 3-16 semi mounted plow?
Hugh MacKay
03-16-2006 03:47:01
 Re: Tractor wheel spacings in reply to Allan in Nebraska or anyo, 03-15-2006 15:56:40
Technically you have too many variables to give you a precise answer. Number of bottoms is one factor but you must also factor in width of cut of each bottom. Then you must take into account tire size.
If you can locate one, there are charts giving the ideal setting for every variation of number on bottoms, width of cut of each and tire size. This chart will apply whether plow is mounted, semi-mounted or trailing. You can also vary on that setting by probably 10%, and still do good plowing. However if the setting is perfect you will pull the plow much easier.
I had one of these charts years ago. I would expect they are still available from county ag reps or ag engineering depts. I wouldn't disturb anyone in sales these days, the guys that knew are either retired or dead. Allan's basically got it right.
the tractor vet
03-15-2006 17:38:24
Guess i posted before i read completly Also are you going to use in it in the row between the crops or not .
the tractor vet
03-15-2006 17:35:10
Mounted , pull or semi mount ????
Allan In NE
03-15-2006 16:23:17
Hi Guy,
Don't know your plow nor your tractor.
However, measure from the "centerline of pull" on the plow out to 16" beyond that first bottom's leading edge; this will put you at the furrow wall.
Then, add half the width of your rear furrow tire and an inch or two for tire squash. Double that figure and you should be in the ball park for total stance.
Hope I got that right with my cowboy chypherin'. :>)
Allan
