Order Farmall Cub Parts Online
farmall cub vs lowboy
dduny4
03-15-2006 19:14:46
What is the difference between the two?
I have a 1952 and a 1963, both are f cubs.
Nat 2
03-16-2006 05:52:30
 Re: farmall cub vs lowboy in reply to dduny4, 03-15-2006 19:14:46
Yup, 8" in height, 8" in wheelbase, and the various parts required to lower the Lo-Boy. The final drive housings are different, and most of the parts in the front end are different.
All the implements are different too. There are special versions to fit the loboy.
Stan(PA)
03-16-2006 05:50:08
Main difference is 8 inches in height. The loboy has shorter spindles in front, and the rear bullgears are rotated to lower it. I"m fairly sure everything else was the same.
