M rear housing repair
Travis
03-16-2006 05:26:02
Hey all, Got an M here that has a broken rear housing that leaks. Someone has tried to braze it but it still leaks. What is the best way to fix this without just changing the whole rear end? I can't braze or weld very well upside down so thought of flipping the tractor over a bit so I could weld it up better. Does anyone else have any good ideas? Thanks
souNdguy
03-16-2006 07:33:57
 Re: M rear housing repair in reply to Travis, 03-16-2006 05:26:02
Ditto on the epoxy if it is not a structural failure.. I'd go at it from the inside if you can get all the oil out.. clean it with naptha or carb cleaner and run the epoxy ont he inside.. if not.. clean well and do the outside.
Soundguy
Janicholson
03-16-2006 06:14:35
If the crack is from Ice or other internal force pushing out, and is not structural. I would clean the area around the crack with a wire brush till it was shiny then use a flexible epoxy material to coat on a layer about 1/8" thich in the middle, tapering to the edges. Hooking a vacuum cleaner to the fill plug can assist in getting the oil out of the crack, and pulling epoxy in while it hardens!
If it is structural, I would recommend replacing the housing. (or entire rear end) Welding is possible, I would remove all signs of brass, drill small 1/8"dia holes at the ends of the crack, "V" the crack almost through the thickness, and use Ni rod to fill the groove. Weld an inch, stop and use a pick hammer or weld slag hammer to peen the boogers out of the bead. Then weld another short pass (1") and peen again. I've welded transmission tunnels on Ford 4000 tractors, where the single sided loader attaches (a foot ball sized chunk), with success. Patience, good practice, and a nice welder.
JimN
