Super C/International 37 baler
Rusty Shafer
03-16-2006 11:12:30
Will a farmall super c run a international model 37 baler? or is it underpowered. Will it run any baler? Thanks in advance Russ
matt in pa
03-17-2006 05:44:29
 Re: Super C/International 37 baler in reply to Rusty Shafer, 03-16-2006 11:12:30
Sure it will.
Take your time, and a Super C will have enough power for the job, but be aware that it is a very light tractor and don't try any fancy driving on hills. We used to bale with a 300 pulling the baler and wagon, and on occasion when the 300 went down we would drop the wagon, hook the 230 to the baler, and away we would go. The 230 model is basically the same tractor as the Super C, but maybe a few more ponies.
Russell Shafer
03-17-2006 06:09:06
 Re: Super C/International 37 baler in reply to matt in pa, 03-17-2006 05:44:29
Thanks for the help, Where in pa are you?Rusty
Hugh MacKay
03-17-2006 02:44:40
Rusty: It sure will run the baler, back 50 years ago we had a neighbor, who never owned a tractor heavier than a Super C. He had to have been baling 25,000 bales annually as he had 100 holsteins in an area that had 7 months stored feeding. I remember it being a PTO driven baler, and his dad well into his 70s did all the baling. Man could that old guy bale hay. He never pulled a wagon behind, but he did bale on hills, some of them quite heavy hills.
The old guy was rounded over from many years of hard work. Most folks said it was because he pushed the Super C so hard on the baler, that everytime the plunger made it's stroke, the impact draped the old guy over the steering wheel. He was close to 6' and I'll bet he didn't weigh 135# soaking wet.
Rusty Shafer
03-17-2006 06:11:27
 Re: Super C/International 37 baler in reply to Hugh MacKay, 03-17-2006 02:44:40
Thanks for the info it is very helpful. I am going to try it when hay season comes. Rusty
Harold Hubbard
03-16-2006 17:25:11
I don't even want to think about how many bales I did with our old Super C and IH 45 baler. Talk about a slow painful process. We never tried to haul a wagon behind it, just let the bales fall on the ground and picked them up afterward. Second gear most of the time, first gear when the windrows got heavy, and sometimes third gear downhill in light hay with a tailwind. One of the happiest days of my life was when my dad finally bought an M and the Super C got demoted to tedding and hauling the wagon.
On the other hand if a Super C is all you have and you are only going to put up a few hundred bales a year, I would say "go for it". Just take it slow and easy, and do the best possible job of raking ahead of it. Carefully raked, even windrows, without any big wads will go a long way toward making up for the lack of live PTO. I really would not try a wagon behind it unless your ground is just about dead flat.
Rusty Shafer
03-17-2006 06:13:20
 Re: Super C/International 37 baler in reply to Harold Hubbard, 03-16-2006 17:25:11
I plan on taking my time,and intend to rake very carefully.Thanks, Rusty
gene bender
03-16-2006 17:12:24
You bet she will just dont make the windrows too big. You want 12-14 slices per bale.
Russell Shafer
03-17-2006 06:15:06
 Re: Super C/International 37 baler in reply to gene bender, 03-16-2006 17:12:24
Thanks Gene, I need all the encouragement I can get. There seems to be mixed views on the subject. Rusty
350 HU Don
03-16-2006 15:23:35
A Super C will handle a baler and wagon, presuming the tractor is in good shape. I'd be careful on the hills but I wouldn't hesitate a minute to bale with a Super C. As a much younger man I baled thousands of bales with a H Farmall, a 14T John Deere baler, and loaded the wagons to about 130 bales per load. The only time we had any trouble was when the sidehills were so steep the bales would slide off the side of the wagon. Then we'd drop the bales and come back later with the wagon to load them.
I'd say "go for it".
Rusty Shafer
03-17-2006 06:17:04
 Re: Super C/International 37 baler in reply to 350 HU Don, 03-16-2006 15:23:35
Thankfully all the ground I work on is flat. so hills won't be a problem. I'll go for it. Thanks, Rusty
Tractor Dan
03-16-2006 14:11:34
yes a super C will run a 37 baler i had a 37 that came off a farm where the big tractor was a C or super C i dont remeber for sure but that is what they ran the baler with i used my 350 diesel but for year i helped a friend who baled with a super C and john deere 14t worked fine used a bale buncher i mean it was alot nicer running with the 350 with live power but the C did just fine and we baled some thick hay
Rusty Shafer
03-17-2006 06:22:53
 Re: Super C/International 37 baler in reply to Tractor Dan, 03-16-2006 14:11:34
Dan, I also have a 350 D but it is in sad shape. It was started on as a restoration,engine done with new sleeves, pistons, head done,etc. The shame of it all is it was left outside and got filled with water. You know the rest. I am currently looking for a motor for it so I can start the restoration over.It still needs many parts.Huge project. I'm going to try the Super C and see how it does. Thanks, Rusty
Janicholson
03-16-2006 12:14:40
The short answer is no. No live pto, not sufficient power.
The longer answer is sure if the bailer has an engine on it.
The C will have a difficult time controlling a wagon load and baler. Dropping the bales would work.
My two cents,
JimN
steve from mo - dangit!
03-16-2006 12:02:07
 Too light. in reply to Rusty Shafer, 03-16-2006 11:12:30
A fresh Super C would likely run a small square baler ok on level ground with light hay and no rack or kicker. It's really too light though and you'd get pushed around a lot the baler behind you.
Yugrotcart
03-16-2006 12:58:35
 Re: Too light. in reply to steve from mo - dangit!, 03-16-2006 12:02:07
I would think it should work. If not I'll bring my W6 over, we'll "Git her Done"..... ....
