Finally found a plow - Little Genius??
Ksfarmmer
03-16-2006 15:12:53
Well, after months of shopping I finally came home with a plow yesterday. Based on pics from the implement section, I'm guessing this is a Little Genius plow. It is a two bottom, steel wheeled plow. The only markings are IHC and several PO XXXX type numbers. How can I tell for sure if this is a Little Genius and does anyone know if there are still manuals available to help with the setup. I can probably figure it out, but a manual would certainly make it simpler.
Larry in CO
03-16-2006 19:51:50
 Re: Finally found a plow - Little Genius?? in reply to Ksfarmmer, 03-16-2006 15:12:53
Hi KS,
Does the plow have a tail wheel? The Little Genius has a tail wheel and the Little Wonder does not. I've got a 2-14 Little Wonder. If you're looking for a manual for it, I might suggest Binder Books dot Com (no spaces). I was able to get one for my Little Wonder a couple of years ago. Not too expensive either.
If they don't have the manual listed for your specific plow, give 'em a call. That's what I had to do to get mine.
HTH,
Larry
