274 off-set diesel steering problem
Shaun Arms
03-16-2006 20:05:48
I'm having trouble with the worm gear,ball bearing,and the thing the worm gear goes inside. The worm gear got chipped and I silver soldered it and replaced the bearings and it lasted about 45 minuites and the same thing happened again.Is there any way I can fix this problem. Thanks in advance.
Nat 2
03-17-2006 12:08:43
 Re: 274 off-set diesel steering problem in reply to Shaun Arms, 03-16-2006 20:05:48
You'll need to replace the gear, maybe both the sector and the worm. Silver solder is not meant to replace missing gear teeth, so it's no wonder it didn't last long.
