Server Problems
Kim
03-17-2006 08:52:14
We're having some very serious problems with the server this morning that seems to be affecting the posting of new messages.
I've set up some Alternate Forums that we can use in case it gets worse and worse. We have a new server that we just purchased but it might be awhile until we can get it going.
The Alternate Forums aren't like our regular forums as far as the software, but at least it is something we can use to stick together while the problems are being worked out. The link is available under the Community heading in the left hand menu.
Here is a direct link:
Alternate Forums
Thanks!
NDS
03-17-2006 14:13:30
 Re: Server Problems in reply to Kim, 03-17-2006 08:52:14
Thanks for the great job you do Kim and thanks to the reminder from Hugh guess it is about time I antied up again.
NDS
03-17-2006 14:19:24
 Re: Server Problems in reply to NDS, 03-17-2006 14:13:30
Sorry Hugh, should have said MagMan.
Steven@AZ
03-17-2006 10:26:37
Thanks for thinking of us! I know I appreciate this website and the work you do to keep it running very much.
Kim
03-17-2006 10:26:21
It appears to be a problem with too many network connections... is getting better and we'll keep on top of it. Thanks for your patience!
