distributor rebuild....
Jesse
03-17-2006 17:45:34
Just curious..if you forgot the clearance on the breaker/point when you rebuild the distributor..and run the engine for about 30 minutes...can it harm anything?
NDS
03-17-2006 17:47:31
 Re: distributor rebuild.... in reply to Jesse, 03-17-2006 17:45:34
NO.
brandonf
03-17-2006 20:39:59
 Re: distributor rebuild.... in reply to NDS, 03-17-2006 17:47:31
since this thread has started I need some help on dist rebuild.. what should I do with the springs and flyweights for a performance rebuild I do not have acces to a sun distributor dyno or what ever you call the machine
could you give me any advice
thanks brandon
NDS
03-18-2006 06:24:41
 Re: distributor rebuild.... in reply to brandonf, 03-17-2006 20:39:59
Can not help you with that you would probaly get better results asking that question on pulling forum.
