tractor problems
tom106
03-17-2006 18:40:37
can anyone tell me on a international 444 how does the hydralic fluid get into the crank case and build up enough pressure to blow the hydralic fluid out the air intake or oil filler tube thanks for any help
CNKS
03-17-2006 19:40:47
 Re: tractor problems in reply to tom106, 03-17-2006 18:40:37
The pumps are not necessarily shot if the seal is bad -- try the seal first, you may also need a speedy sleeve on the shaft if it is worn excessively.
the tractor vet
03-17-2006 20:18:25
 Re: tractor problems in reply to CNKS, 03-17-2006 19:40:47
BTDT if the seal on that pump is leaking and filling the crakcase the pump is junk toast scrap and there is no fixen , trust me we played that game . Your not working on a pump that only makes 1000 psi .
the tractor vet
03-17-2006 19:36:18
get a new Hdy . pump and your problem is cured , don't even waist your time tryen to put a seal in it as it will not hold the shaft bushings are shot and the shaft is junk now.
Janicholson
03-17-2006 19:15:55
Without more info my best guess would be through a bad seal on the input shaft of the pump (assuming it is located on the engine right side up front. If this seal leaks it puts fluid into the crankcase.
JimN
