6.5 l diesel
bm3501466
03-18-2006 12:31:44
I have a 6.5 GM diesel in my truck. It does not want to start easily. Everytime I fill it up with fuel it acts up again. It will die and sometimes not even start after I fill it up. What is wrong with my truck?
El Toro
03-18-2006 17:45:05
 Re: 6.5 l diesel in reply to bm3501466, 03-18-2006 12:31:44
Have you changed the filter lately? You may be stirring up dirt in the tank when filling the fuel tank. I would check the fuel pressure too.
You need to make sure all fuel connections on the suction side of the pump are tight and are not sucking air. Hal
hot shot
03-18-2006 16:59:40
Sounds to me like you are running it out of fuel. Fill it up before it quits. Diesels don't run without fuel
bm3501466
03-18-2006 19:11:09
 Re: 6.5 l diesel in reply to hot shot, 03-18-2006 16:59:40
I know better than that hot shot.
Dave_Id
03-18-2006 16:56:39
This may be the wrong forum for GM
