Seat Spring
Andrew Z
03-20-2006 10:22:52
Does anyone know where to get a seat spring that will not go down all the way when a 250lbs guy is on the seat? The shock is fine so I dont think thats the problem. thanks Andrew
trickster
03-21-2006 02:04:10
 Re: Seat Spring in reply to Andrew Z , 03-20-2006 10:22:52
When I did mine last year I thought replacing the rubber bushings helped as much as the new shock. My 2 cents
Will Sick
03-20-2006 22:16:37
The strongest spring has a number 5 near the top or 5 lines. These would be of the original IH. I don't know about the reproductions that they sell.
Wayne Swenson
03-20-2006 12:38:34
Look for an original spring with 4 notches cut into the top of the spring usually within the last 2" of the spring end. Fewer notches = less strength.
Robertw
03-20-2006 11:19:39
I've got a farmall super h which has the shock ahead of the seat spring. I took a spring that goes over a car shock cut it to the length that i needed put over the tractor shock painted it farmall red looked good and you can adjust it to the firmess that you want works great.
Robert in mich.
RustyFarmall
03-20-2006 10:34:12
Send me an e-mail.
