Re: Timing an M
Hermit
03-20-2006 16:25:37
With a distributor-points set at .020 and breaker arm spring tension at 21-25 ounces-degrees and rpm at crankshaft:
0 degrees at 400 rpm
19 degrees at 800 rpm
34 degrees at 1200 rpm
40 degrees at 1600 rpm
From IH-8
the tractor vet
03-20-2006 19:44:47
 Re: Timing an M in reply to Hermit, 03-20-2006 16:25:37
That is one of the old settings now total is limited to 27 degrees
