H farmall crank
Jk20
03-21-2006 05:25:50
Where on a H Farmall did the hand crank go, is there a special bracket or designated place?
evilbowevil
12-31-2009 07:44:26
 Re: '48 Cub hydraulics question. in reply to BenB, 12-30-2009 22:03:45
ralphscubs.com will have all the parts needed to do this
good luck
Ron
DHB
03-21-2006 06:55:59
 Re: H farmall crank in reply to Jk20, 03-21-2006 05:25:50
Mine is sitting on top of the rear tire of my Massey 44. If you figure out where to put it on the H, let me know!
Wayne Swenson
03-21-2006 06:09:34
We used to put it along the right side of the engine between the block & the frame rail. There is no "correct" place I know of unless you pin it to the shaft sticking out the front.
