Farmall H Carb leaks out the weep hole
John in Ct
03-23-2006 18:08:22
I rebuilt the carb on my farmall H a few months ago. I haven't run it in a couple of months. I did not shut off the fuel. There are no carb leaks except the felt weep hole ( on the bottom of the carb) always has a drop on it. There is no puddle or drops on the concrete floor. I took off the rubber air cleaner hose and stuck my finger on top of where the weep hole is and it always is dry. Ant thoughts? Thanks!!
Roger46
03-23-2006 19:35:26
 Re: Farmall H Carb leaks out the weep hole in reply to John in Ct, 03-23-2006 18:08:22
John, I think that unless you shut off the gas and run all the gas out of the carb you will always have a spot of gas there. Since that is an up-draft carb any fuel left in the manifold after you shut off the engine will condense and collect at the weep hole. I only shut off the gas on my show tractors and run the gas out of the carb to keep the paint nice. On working tractors I never shut off the gas and have never had any leaks other than a little drip at the weep hole. If you have leaks you have a bad float/needle valve. Roger
Jim Broughton
03-23-2006 18:41:13
Because the "H" is gravity flow...ALWAYS SHUT-OFF the gas at the tank !!Saves a lot of gas as well as reducing a fire hazard !! Good luck !! Jim
Allan In NE
03-23-2006 18:44:18
 Re: Farmall H Carb leaks out the weep hole in reply to Jim Broughton, 03-23-2006 18:41:13
Jim,
I've lost more fuel out thru the gas cap via the Oklahoma Credit Card route. :>(
Allan
