farmall m timing
Clint Gabbert
03-24-2006 18:57:43
I have just got a farmall m and am having some problems timing it. it has a mag and a have failed to get it timed right. it starts and runs fine but i can hear it missing, and i dies under a load.and also it blows raw gas from the muffler.. the impuse coupling trips about 3/4 of an inch from tdc. any ideas. thanks
John M
03-25-2006 10:25:03
 Re: farmall m timing in reply to Clint Gabbert, 03-24-2006 18:57:43
Sounds more to me like your flooding.The impulse does trip ahead of TDC.Unless the inners were messed with,the mag can only go on two ways,and one aint right,so if it runs any,that has to be the right way.The mag wouldnt have anything to do with you blowing raw fuel out the muffler.Maybe a stuck valve?
Magman
03-25-2006 08:36:29
If you continue to have problems and want help with the timing I am here all day today working on mags and watching the race so email me and I will give you my phone #.JON
Farmall Magneto site
Clint Gabbert
03-25-2006 18:22:08
 Re: farmall m timing in reply to Magman, 03-25-2006 08:36:29
Thanks for the offer but, i think i got it!!
What i did was, left the mag bolted to the housing and pulled the mag and drive gear housing in one unit. I set #1 to TDC rolled the rotor too the #1 plug term. reinstalled the thing,rolled mag till i heard the SNAP.
pluged in the #1 plug wire and started her up, then connected the rest of the plug wires."Sounded
like a Beast"
then i proceeded to brush hog a 3 acer field in 4th gear with no problem other than some white smoke. But when i got this thing it was only running on one cyl; and for no telling how many years, so i figure there is some build up in the other three that it is burning off.
Hayfarmer
03-25-2006 07:23:47
After you check all the easy things mentioned below, if you still have a problem check the cam gear. I had a problem on my smta when I first got it, would run but not like it should, also did not start good. Realized it was blowing air out the intake. Found cam gear loose and a chipped cam end.
El Toro
03-25-2006 05:02:17
You should check the cap for any tiny cracks if there's any burnt terminals in that cap I would change it and the rotor. Hal
El Toro
03-25-2006 04:57:37
It could be your plugs, plug wires, should be copper wires and check valve lash. Set them at .020" cold. If it still misses you should check the compression. Could need a valve job.
Hal
Bob
03-24-2006 23:49:55
If the impulse "clicks" pretty close to #1 TDC, you've got the timing darn close.
When the engine starts, and the impulse "kicks out", the advance will jump to full running timing all at once.
Assuming you have the correct mag (impulse "lag angle" does vary), it is working properly, and firing at close to TDC at cranking, your timing is close enough so that it is NOT the cause of the problems you are having.
Sounds to me like spark plug wires scrambled around, or a valve problem. (Sticky ar burned valve(s).)
