Cannot find oil dipstick on my 300
muksrat
03-25-2006 11:40:50
I want to check the oil on the 300 I recently purchase but cannot find the dipstick.
Harold H
03-25-2006 18:29:33
 Re: Cannot find oil dipstick on my 300 in reply to muksrat, 03-25-2006 11:40:50
If your 300 was originally a distillate tractor it will not have a dipstick but will have petcocks like the H & M. Gasoline 300 should have a dipstick but it is possable someone might have swapped the original engine for a H or SH engine which did not have a dipstick.
Harold H
skipper
03-25-2006 12:36:37
At least some 300's have petcocks on the right side of the crankcase to check the oil. There will be two, one slightly higher than the other. To check the oil turn them ccw till they are loose and the oil should run out slowly. Keep the oil level between the two.
Skipper
Lane
03-25-2006 11:47:19
It would be on the right side, underneath distributor and kind of in line with the frame rails, it should be a pull out type dip stick
