Farmall's
HPK
03-25-2006 13:36:46
I have a few questions I would appreciate some help with. We are restoring a Mod. A, near as we can figure it's a 1942, did they not produce tractors in 1943? Also can someone explain the differences between a Mod. C and a Cub. We also found what was labeled to be a B. It really looked like an A. Is there alot of differences between the two models? Any help on these questions would be greatly appreciated. thanks
HPK
03-28-2006 05:57:49
 Re: Farmall's in reply to HPK, 03-25-2006 13:36:46
Thank You for all your replys. I see why I was having problems telling the difference, there is not much difference at all. Always helps when they leave the model plate on the tractor. Thank You all again..
MNredfarmer
03-25-2006 13:48:57
Models A,B and C all used the 113 cubic inch engine. The cub used a little flat head engine and was a much lighter tractor. The A had a wide front and the B had a narrow front. There might have been a little differance in the rear end too, i'm not sure. they were both offset I think. The C's engine was centered on the rear end.
Dave H (MI)
03-25-2006 13:59:43
 Re: Farmall's in reply to MNredfarmer, 03-25-2006 13:48:57
third party image
The B was centered also. It was the seat that was offset. Here is pic....this is a sale tractor I considered but did not buy.
Mr. Farmall
03-25-2006 16:30:06
 Re: Farmall's in reply to Dave H (MI), 03-25-2006 13:59:43
What is that on the back of that B? is it a 3 point hitch thing on that?
Dave H (MI)
03-25-2006 18:03:21
 Re: Farmall's in reply to Mr. Farmall, 03-25-2006 16:30:06
third party image
Yessir. This fella had dummied up a three point hook up and had a mower on the back end. Can't remember where this tractor was located but thinking it was over in western Michigan. I wasn't impressed with the condition so I let her go buy and bought this one a month or two later.
Just needed to replace the Monroe seat and it was ready to go.
Mr. Farmall
03-25-2006 18:28:23
 Re: Farmall's in reply to Dave H (MI), 03-25-2006 18:03:21
Thanks for the reply Dave.
Mr. Farmall
03-25-2006 13:47:46
Models A,B,C are very similar tractors, The A and B both used the same C113 OHV engine and 4 speed transmissions, while the C has the same C113 OHV engine but a differnt transmission. The A is a wide front while the B and C are narrow fronts. The Cub looks similar to the A but it is smaller and has a smaller C90 flathead engine and a three speed transmission, hope that helps.
Andrew Z
03-25-2006 14:01:15
 Re: Farmall's in reply to Mr. Farmall, 03-25-2006 13:47:46
The cub has the C60 engine and the C was avaible with a wide front the B was not.
