'39 f20 spark/gas control removal
flayvous ray
03-26-2006 09:19:02
to remove the hood on my f20, the book says to remove the gas/spark contro and rod. i don't see how to do this. they seem to work against each other and will not slide in either direction. i don't see a nut or bolt holding them. can someone please advise how to remove these items?
Sloroll
03-26-2006 09:49:56
 Re: '39 f20 spark/gas control removal in reply to flayvous ray, 03-26-2006 09:19:02
Towards the radiator end there is a cotter pin and spring on the rods. Remove these and unless (which is often the case) the rods are rusted together,the inner and outer rods will pull free from each other.
