farmall M hydralic leak
dairyman
03-26-2006 18:38:21
I have a farmall M that has a M&W live hydralic pump on it and uses the orginal resivor; it appears to be losing oil from the bottem of the resivor. what i need to know is where the leak is coming form is it a bad seal on the bottem of the resivor or is it caused by another problem? also what should i expect when I take it apart? Thanks for the help.
Dairyman
CNKS
03-26-2006 19:53:11
 Re: farmall M hydralic leak in reply to dairyman, 03-26-2006 18:38:21
If it is leaking from the reservoir, you will see it. If you don't see it, the seal on the pump is shot, and it is leaking into the crankcase. A new seal and a speedy sleeve on the shaft (if badly grooved) will fix the problem. Open the top petcock on the oil pan and see how much oil comes out.
dairyman
03-27-2006 04:21:41
 Re: farmall M hydralic leak in reply to CNKS, 03-26-2006 19:53:11
the leak is visable on the bottem of the hydralic resivor. thanks for the information it sounds like it will be an easy repair.
