Order Farmall Cub Parts Online
Farmall Cub stalls when warmed up
DickR
03-27-2006 08:12:53
I own a Farmall Cub model F. I'm experiencing two problems which I don't believe are related.
1. The tractor stalls after running about 20 min. Starts fine, runs smooth but after 20 min it begins to run rough and soon sputters to a stall. It will not restart immediately, but after a half hour or so it will start right up and run for another 20 min. I thought it was the valves so I had a valve job done, but the problem persists.
2. The governor does not kick in under load, though the throttle works fine.
Any help would be appreciated.
Janicholson
03-27-2006 11:48:10
 Re: Farmall Cub stalls when warmed up in reply to DickR, 03-27-2006 08:12:53
I like the comments below, and would add that feeling the coil just after it dies will pinpoint it as the cause. If it is so hot that you cannot keep your hand on it, replace it.
The second it quits, the center distributor cap wire, and hold it (with well insulated pliers) about 1/4" away from the block. Try to start the engine (neutral and brakes on) If no spark, coil or mag issues. Magman is the Mag answer.
JimN
DickR
04-20-2006 06:08:23
 Re: Farmall Cub stalls when warmed up in reply to Janicholson, 03-27-2006 11:48:10
It was the coil! I tried your test and sure enough the old coil got hot. Thanks so much for you help.
MAGMAN
03-27-2006 10:15:45
Sound like it could be the coil or Fuel . What does it have a Mag or distributor? If you need anything you can go to www.farmallmagneto.com and I will be glad to help. JON
DickR
04-20-2006 06:10:08
 Re: Farmall Cub stalls when warmed up in reply to MAGMAN, 03-27-2006 10:15:45
It was the coil! Thanks so much for your help.
El Toro
03-27-2006 10:10:47
It sounds like the coil, but I would make sure your gas line isn't plugged. Hal
Laurence
03-27-2006 10:09:13
Sounds like fuel starvation to me. Loosen the cap on the fuel tank and see what happens. The air bleed hole can easily get blocked. Especially if the cap is painted during a paint job.
old
03-27-2006 09:08:34
My guess also is the coil is going bad on you. As far as the govanor start it up and by hand try to open up the gov, does it puch back when you do so. If not you probably have a bad gov also. The throttle is a fuction of the gov. so its also not working right or its hooked up wrong some how which I have seen more then once. Some one may have hooked up the carb/gov rods wrong at some point
DickR
04-20-2006 06:13:43
 Re: Farmall Cub stalls when warmed up in reply to old, 03-27-2006 09:08:34
It was the coil! Thanks so much for your advise.
Peabody
03-27-2006 08:37:35
Sounds like you have a bad coil. They will do that, work OK until warmed up, then sputter and die. Wait awhile to cool down, crank back up and the same thing happens.
