Oil for hydralic lift on Super A
Dente
03-27-2006 11:25:03
What is the best oil to use to fill the hydralic reservior on this tractor? Can hytrans be used?
El Toro
03-27-2006 13:41:20
 Re: Oil for hydralic lift on Super A in reply to Dente, 03-27-2006 11:25:03
You can use Hytran or Hygard from JD. If the oil hasn't been changed I would drain the hydraulic system and install new oil. I would stick with
whatever you use if you ever need to add some. Hal
Janicholson
03-27-2006 11:39:59
Hytran is good, If you use the SA with a remote that is also used by other tractors, settle on a common high quality Hydraulic fluid and use it in everything. Many long discussions have indicated to me that all brand name fluids will be operational and safe. mixing them may not be a good policy, but the quality fluids meet (or exceed the requirments)
(my only exception is hydrostatic tractors of any type should use the recommended fluid only)
JimN
