340 fast hitch linkage
Blazing Bruck
03-27-2006 14:57:20
Just picked up a sharp 340 with fast hitch. Hydraulics are squealing like crazy. Return tube ftom the valve stack gets hot fast. The fast hitch linkage is not adjusted properly, as there is almost no movement of the actuating rod at the hyd. valve when you move the quadrant. This is a first for me. Does anyone have a procedure for adjusting the fast hich linkage? My books don't show this. Thanks
J. J. from Afton
03-28-2006 20:00:57
 Re: 340 fast hitch linkage in reply to Blazing Bruck, 03-27-2006 14:57:20
Glad to help. Hope it works for ya
Blazing Bruck
03-28-2006 17:37:02
Yep, thats where the adjustment is. I'll try playing with it tomorrow and see if I can get it to work. Many thanks to all who responded. I'll report my progress.
J. J. from Afton
03-28-2006 13:47:44
Well on the 340 utility you adjust the linkage between the seat and the remote, by disconnecting the linkage under the seat. So i believe the Farmall 340 should have something similar.
J. J. from Afton
03-27-2006 20:47:33
where is the hydralic lever located, next to the seat or next to the dash?
Blazing Bruck
03-28-2006 03:38:37
 Re: 340 fast hitch linkage in reply to J. J. from Afton, 03-27-2006 20:47:33
The quadrant lever for the fast hitch is next to the seat on the righ side. The hyd. lever for the external remote is on the right hand side of the dash.
