H timing gears
sgtbull
03-27-2006 18:51:51
I've found that my idler gear between the crank gear and governor has two broken teeth. The crank gear has LOTS of wear on it, way more than the cam or the idler...I s'pose since its doing double duty and is the smallest of the three, that's expected. I'm going to buy a new crank gear, but can't find the idler gear new. I've always heard its bad juju to mix new and old gears, but it doesn't look like there are many alternatives....any input on that? Also, does anyone have an H cracked open w/ a good idler gear they'd be willing to part with?
CNKS
03-27-2006 19:46:22
 Re: H timing gears in reply to sgtbull, 03-27-2006 18:51:51
Calll Mike Bunck at Steel Wheel Ranch - 785-548-7437 - He might have gears off the same engine. At any rate he will have all the gears you need.
Don L C
03-27-2006 19:04:30
Would this be a good time to replace these gears with SUPER H gears?..... I seam to rember that was recomended if you was installing two way hydrolic pump on a Farmall H.....
CNKS
03-27-2006 19:44:10
 Re: H timing gears in reply to Don L C, 03-27-2006 19:04:30
Yes, it's a good idea to change the gears if you are installing a distributer mounted (live) pump. The pump itself does not make the system two way, for that you need an OEM "christmas" tree, or a spool valve.
