440 lok twist wire baler problem
Rowan
03-28-2006 08:42:12
Have a 440 lok twist wire baler that giving me a problem. When the tieing mechanism kicks in it won't quit, just continues to attempt to tie and makes a big knotted mess out of the wire. Bought this baler over 10 years ago without much baler experience. It has been such a good trouble free machine that its never had a break down, therefore I don't have much troubleshooting ability. Theres not any of these old machines in my area so local help isn't available. I would appreciate any insight into what the malfuntion is.
mbnok
03-28-2006 18:51:42
 Re: 440 lok twist wire baler problem in reply to Rowan, 03-28-2006 08:42:12
Check the plastic spacer in the bale length? Look for flat spots. It some times has to be replaced If it has much of a flat spot. When it keeps on tying it will be something in the bale length mechanism. If I remember right you have to move the base part a little to the rear. I don't have my books any more so I can't call the correct names. You are right in that these balers baled many bales between problems.
