1066 Front Tires
Michael Sheik
03-29-2006 05:56:14
The front tires on my 1066 have a lot of age on them and one was booted before I bought it. They are 10.00x16 and little concerned that they are unsafe on road in high gear and do not want blowout 8 miles from shop. I was wanting to put new 11.00x16s on it for a little more flotation and wanted to go with 4 rib as they look better. The thing is that right now there is approx 3/4 inch clearance between inner edge of tire and the little steel block welded on the outside top of the spindle tower. I know tire brands can vary but do you all think the 11.00 is that much wider that it could rub. Tire man is unsure!
John A.
03-29-2006 11:52:31
 Re: 1066 Front Tires in reply to Michael Sheik, 03-29-2006 05:56:14
Michael, I have a 73 966. It came with impliment tires on it. It was a very short while before I changed out to airplane tires. I am on my second set of 32x11.5x15. These tires are ....front tires on a Boeing 727. More than capable in doing the Ag work on a farm tractor. They really shine if you use a loader on your 1066. my original factory floatation rims worked just fine on my first set. On my second set, I up graded to HD rims with thicker centers than my OEM ones. They cost me $70 ea, the tires cost me about 70 too. There is still about 3/4 of an in cleaarence between the tire and the steel block wedge you spoke of.
My first set of tires went 10 yrs....Long enough, Don't you think.
Allan has a pic or two of my ol girl w/ her old first set of airlpane tires still on it. Maybe he will post it late for you to see.
I will NEVER go back to Ag tire on the front.
Hope this helps!
Later,
John A.
Harold H
03-29-2006 11:23:24
I would recommend you stick with the 10:00. I don't think the 11:00 was even an option on the F-1066 when new. Probably would rub. Also 3 rib was standard.
Harold H
Michael Sheik
03-29-2006 08:13:50
 Re: 1066 Front Tires- Allen in reply to Michael Sheik, 03-29-2006 05:56:14
ya I thought of the stress load potentials. Maybe I should just stay with the 10.00.
Allan In NE
03-29-2006 08:24:47
 Re: 1066 Front Tires- Allen in reply to Michael Sheik, 03-29-2006 08:13:50
I dunno,
Think I'd stay with that original size if it were mine.
Had a spindle snap in the field one time. They sure come down in a hurry. Kinda catch ya off guard too. :>)
Allan
Dr.EVIL
03-29-2006 07:55:14
An 11.00 is quite a bit bigger than a 10.00. Firestone has a real nice website for ag tires and You should research things there like section width and loaded radius on the 10.00 & 11.00. I really doubt reversing the wheel on the hub will gain You any clearance... If Your front wheels are anything like the 86 & 88-series had the bare OEM wheel won't even bolt on that way.
Allan In NE
03-29-2006 08:22:26
 Re: 1066 Front Tires in reply to Dr.EVIL, 03-29-2006 07:55:14
Here,
Maybe this will help from page 63 of the owner's manual. All IH wheels are swapable; up thru the 66 series anyway.
Allan
third party image
Dr.EVIL
03-29-2006 13:25:36
 Re: 1066 Front Tires in reply to Allan In NE, 03-29-2006 08:22:26
The 16" frt wheels, 10.00, 11.00 & even the 14Lx16.1's the wheels would only mount dished out, concave. The 15" 6-bolt wheels "COULD" be mounted either way since at least the stamped centers were welded into the wheels dished in, or convex.
Allan In NE
03-29-2006 14:21:16
 Re: 1066 Front Tires in reply to Dr.EVIL, 03-29-2006 13:25:36
Doc,
Was just reading that. Has he got the wrong wheels on that thing, then?
1066 up thru the 1466 should have come with the 11LX15 tires/wheels, right? Supposedly, they didn't start the 16 inchers until the 86 series (not counting the high-crops)?
Dunno, I've never owned an 86 series large frame.
Allan
Dr.EVIL
03-29-2006 15:40:20
 Re: 1066 Front Tires in reply to Allan In NE, 03-29-2006 14:21:16
IH did use a LOT of 9.5L & 11L x 15 tires/wheels during the 66-series but never on the 86 series. Yes, a few 886's & 986 snuck out with 9.5L's. Those were all 6-bolt wheels however. And the hubs & wheels had different back spacing and probably could be mounted either way, in or out. The 16" however could not. I personally like the 9.5L & 11L 15's.... depending on rear tire size the old girls either sit level or slightly nose Down!
Allan In NE
03-29-2006 07:19:24
Flip the dish of the wheel.
Allan
Michael Sheik
03-29-2006 07:26:13
 Re: 1066 Front Tires in reply to Allan In NE, 03-29-2006 07:19:24
Lug bolt holes in the wheel are beveled both sides???
Allan In NE
03-29-2006 07:28:21
 Re: 1066 Front Tires in reply to Michael Sheik, 03-29-2006 07:26:13
Yep,
One side is close, the other sets out a little. If yours is setting at 3/4" now, it means that they are set in.
Allan
Allan In NE
03-29-2006 07:33:12
 Re: 1066 Front Tires in reply to Allan In NE, 03-29-2006 07:28:21
Be aware tho, Mike,
When they are set out like that, it puts more of a strain/load on the spindle. I always liked to keep 'em tucked in close.
Allan
