454 Front Hub needed
James Creek
03-29-2006 12:43:45
I am in need of a front hub from a 454 or 2400A international tractor. The part no. is 406292R11 the casting no. is 406292R1 on the part itself. If anyone can help it will be appreciated.
cbontca
03-29-2006 16:21:20
 Re: 454 Front Hub needed in reply to James Creek, 03-29-2006 12:43:45
You should be able to get one at any wrecking yard. Two I know of are Bates Corp in Burbon indiana and I think Central Tractor in Michigan. there are many other yards that will also have this Part. Also check with your local case/IH dealer, They may have a good used one in there bone pile of old parts. Good luck
