SH head question
jaybird2
03-29-2006 18:20:07
Kind of embarrassed to ask this question because I think I know the answer but just want to check with you guys first.
I just had a super H head repaired and reinstalled it today. I got done torqueing it down and realized that the throttle linkage bracket on the carb side was hanging there waiting to be installed. I forgot to pay attention to where I removed it from and have a feeling it should have been installed on the two studs near number 3-4 cylinder.
Do I have to completely undo the head so that it gets retorqued in sequence or can I just back those two nuts off, install it and retorqe it? Or am I not even installing it in the right place.
Thanks for your help.
Jay
the tractor vet
03-29-2006 18:44:29
 Re: SH head question in reply to jaybird2, 03-29-2006 18:20:07
No just lossen the two and put you linkage on and pull it back down then warm it up to operating temp and retorque it it will be fine . Heck i have done that a couple times while under the alfluince of inkelhol
FarmerSid
03-30-2006 05:00:04
 Re: SH head question in reply to the tractor vet , 03-29-2006 18:44:29
Mine had two nuts on those head studs. Those studs were longer as well. Once I had the head torqued down I put the bracket on and put the two extra nuts on.
Cheers!
Sid
the tractor vet
03-30-2006 07:09:52
 Re: SH head question in reply to FarmerSid, 03-30-2006 05:00:04
Yea your wright on that got thinking about it about 3:30 this morning you torque the head then put the throttel linkage on thats what happens when i go play in the dirt fogs up the brain.
jaybird2
03-30-2006 10:55:39
 Re: SH head question in reply to the tractor vet, 03-30-2006 07:09:52
So are you saying that I better not back off those two torqued nuts by themselves? I don't think my studs are high enough to clear the throttle linkage attachment plate.
Thanks guys.
