340 to 300U
moline
03-30-2006 10:24:07
Hi,I found what is left of a 340U in a wrecking yard.Will the power steering go onto a 300U?are the engines in these tractors the same?
Thanks for the info,Moline
TDK
03-30-2006 17:41:16
 Re: 340 to 300U in reply to moline, 03-30-2006 10:24:07
Moline, the box will fit with at least one alteration. The 340 box is beefier & slightly larger than a 300 box. It will intefere with the sediment bowl. This is not a big deal unless you're looking for origonality. You can put the sediment bowl inline. You may also have to do a small amount of grinding for clearance, can't remember exactly where though.
Nat 2
03-30-2006 10:53:48
I'm pretty sure no, and definitely no.
The 340 is the next evolution of the 330, which was a new tractor model released during the '50 series (350, 450, etc). Rumor has it that the 330 is a 350U rear end with the 340U engine because the engine was ready but the rest of the tractor was not. It's a physically smaller engine, less horsepower obviously.
I think the 340U has a completely different drivetrain from the 330/350U, derived presumably from the Super C drivetrain, with a TA added and some beefing up. The 350's drivetrain was overkill for the horsepower.
PAULIH300
03-30-2006 15:04:58
 Re: 340 to 300U in reply to Nat 2, 03-30-2006 10:53:48
Which is one reason why so many 300U/330U/350Us continue on the job today.....over-engineering....except for the weak-link steering.
moline
03-30-2006 19:40:54
 Re: 340 to 300U in reply to PAULIH300, 03-30-2006 15:04:58
Thanks guys!
