Farmall 300 Carb
Jeff Bauer
03-30-2006 18:25:51
Just want to make sure before I buy one. Will a 300 LP Carb fit on an H??
BillMcC
03-31-2006 03:19:40
 Re: Farmall 300 Carb in reply to Jeff Bauer, 03-30-2006 18:25:51
The 300 and Super H are the same carb, but the Standard H is smaller.
INTom
03-30-2006 20:06:43
Jeff,
The H Farmall has a smaller port between the manifold and carb than the 300. I have seen others retro-fit larger carbs to the original H manifold. But, I would recommend that you change over to the 300 manifold for better results.
Jeff Bauer
03-31-2006 01:44:55
 Re: Farmall 300 Carb in reply to INTom, 03-30-2006 20:06:43
I looked up a manifold for the H and 300 on this website, both show the same part #, so I'm assuming the carbs will interchange??
Levi K
03-30-2006 19:25:20
I would think so, all the 300 is is a glorified H, get some other opinions from the other guys on here.
