Super C Clutch?
trw
03-31-2006 05:34:56
When I get ready to put the new clutch and pressure plate back into my Super C, which way does the clutch go? I have never seen a clutch that does NOT have marked on it which side goes to the flywheel! The hub in the midle of the clutch, with the splines, seems to have a little more sticking out from one side than it does on the other. Hope someone can help me! Thanks!
Red Dave
03-31-2006 05:51:01
 Re: Super C Clutch? in reply to trw, 03-31-2006 05:34:56
I think that if you hold the clutch disk against the flywheel, it will be apparent which way it has to go together. It will only go one way.
"The hub in the midle of the clutch, with the splines, seems to have a little more sticking out from one side than it does on the other"
The part that sticks out farther goes away from the flywheel, toward the transmission.
trw
03-31-2006 17:55:59
 Re: Super C Clutch? in reply to Red Dave, 03-31-2006 05:51:01
Maybe it will be "apparent" when I get the flywheel mounted back on the crankshaft, but when it is laying on my workbench, it will go in either way. Am I missing something here? I will take your advice on the way it goes in, but I just like to know "why" something goes together the way it does. Thanks again!!
gene bender
03-31-2006 14:27:48
You sure are correct RED DAVE but why then do some put them in backwards just dont figure.
