BN with widefront
RCinNC
03-31-2006 06:08:51
I have a question for IHC expert. In my area their is a man that has IHC BN, that has a widefront end. He was told it was factory. I can not find any info on this. To my knowiedge all BNs were narrow front. Can anyone help me. Thank you very much.
shoo_giesty
03-31-2006 21:39:23
 Re: BN with widefront in reply to RCinNC, 03-31-2006 06:08:51
i noticed here in wisconsin in the central part of the state there are alot of b's and bn with widefronts. the grow alot of ginsing in that area and use the tractors for that
Haas
03-31-2006 18:36:33
I've seen a couple like this. They are not factory, but made from the front end off an A or Super A. Of course the A front end is off set, so some modification is required to make things look right and be even on both sides. I've also seen a "B" with hydraulic touch control which was made by taking the engine and clutch works out of a Super A and putting them with the B rearend and front end parts. Fellow that had it for sale swore it was original. I guess it was all original IH parts.
Nat 2
03-31-2006 12:19:02
Look at the front end. It's lop-sided, right? The left side is extended all the way out, while the right is sucked all the way in.
It's a front end off an A.
It's only "factory" in that it was made up using IH parts. That combination was never available FROM the factory. All Bs and BNs were narrow front from the factory.
Shaggy
03-31-2006 08:47:19
My Dads has one set up like that. He put it together years ago just for run and he had a good time arguing that is was all IH parts and not some made up thing. Shaggy
Red Dave
03-31-2006 06:15:32
It's not factory.
It probably is from an A. It would be a very easy change to make if you have a steering box and axle from an A. It is just a bolt-up job. The only thing that wouldn't fit perfectly is the bottom of the grill.
