Cam C Farmall
thumbanger
03-31-2006 12:45:34
I know C-113 dosnt have cam bearnings tore 2 down today. When you rebuild I am lost cams seem to be tight when I removed them but something has to wear out is it the cam or block I know cam bearnings in a car do. So what do you do in this case just put it togeather or what. Very confused. Thanks for any help
thumbanger
03-31-2006 14:01:55
 Re: Cam C Farmall in reply to thumbanger, 03-31-2006 12:45:34
Thanks for the input had me puzzled seemed to be good but blowed my mind. Thanks
Janicholson
03-31-2006 13:57:10
The mild spring pressure, the slow speed of the engine, and the largish size of the surfaces seem to work well. Many modern auto engines, including Volvo and other "quality" marques, use no inserts at all with great success. If they get surface rust in them, use 1000 grit or finer crocus cloth to polish it out. spray with LPS corrosion inhibitor to prevent rust.
JimN
El Toro
03-31-2006 13:38:11
The engine has machined bores in the block for the cam journals. Your local auto machine shop can measure them for wear and the cam journals too. Hal
PS: If you had good oil pressure prior to the teardown I would put it together. I would have the main and rod bearings with .001" clearance to .0015".
